dl42
Apr 22, 2022Aspirant
RBK13 Guest Network
Hi I had not logged into the orbi app for a while as everything seems to have been working fine and there have not been any recent updates to the firmware. When I logged in today I noted that the "...
KevinLiT
Apr 22, 2022NETGEAR Moderator
Hi dl42,
I understand that you would like to know if the guest network is supposed to be separated from the main network devices.
The answer is yes, the devices on the guest network will not be able to connect to any devices on your main network. This is done to ensure that the information on your main network is secured. If you would like all of the devices on your network to be able to communicate then all the devices will have to be connected to your main network.
Please let me know if you have any additional questions!!
Best,
Kevin
Community Team
