Kygord800
Dec 01, 2020Aspirant
RBK13 hooked to a Cox router
I have an Orbi RBK13 hooked to the router provided to us by Cox. I'm noticing that I still have devices hooking up to the cox router and not the orbi's. Do I need to shut off the wifi on the Cox ro...
Dec 01, 2020Guru - Experienced User
Is it a modem/router combo device or just a router?
If its a modem/router combo device, I'd recommend disabling the router part entirely. (hint, disabling wifi doesn't disable the router portion) Contact the ISP for help with that.
Otherwise you'd be in a double nat.
https://kb.netgear.com/30186/What-is-Double-NAT
What actual cox devices do you have (model numbers)?
- Kygord800Dec 01, 2020Aspirant
DTC4141 Panoramic Wifi
It's a router/wife, that's all I know.
- FURRYe38Dec 01, 2020Guru - Experienced User
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Kygord800 wrote:DTC4141 Panoramic Wifi
Better information I found on my Cox App:
Model name: CGM4140COM
Technicolor
Revision 2.2
Suggestions still apply for this as well.
