Kygord800
Dec 01, 2020Aspirant
RBK13 hooked to a Cox router
I have an Orbi RBK13 hooked to the router provided to us by Cox. I'm noticing that I still have devices hooking up to the cox router and not the orbi's. Do I need to shut off the wifi on the Cox ro...
Kygord800
DTC4141 Panoramic Wifi
It's a router/wife, that's all I know.
Dec 01, 2020Guru - Experienced User
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Kygord800 wrote:DTC4141 Panoramic Wifi
