Satish_K_S
Dec 23, 2020Aspirant
rbk13 satellite shows blue light, but still shows backhaul as poor
Hello, I got RBK13 (1+2) dual band mesh wifi in the month of September 2020. I have ground plus one floor. Since I am doing WFH now, I have kept one Satellite in first floor and one on the same...
Satish_K_S
Dec 28, 2020Aspirant
Thanks for the response. Over the Christmas holiday and the weekend, I was trying to setup things like you said, but still I see an issue with Backhaul. Initially, for about 6 hours I got Backhaul status good on Thursday, but after that, it is still the same. I have not changed the position post Thursday that is the day when I got status as good for both Satellite.
I have updated the firmware of router as well as both the satellite, but now I am getting another problem. The router is frequently showing no internet.
alokeprasad
Dec 28, 2020Mentor
Power off all satellites. Try factory reset on the router and set it up from scratch.
Then set up the satellites. Set up the satellites one by one at a good location (30 ft away). When they are each set up with good backhaul, move them to their destination locations.
