dmulder
Jun 14, 2021Tutor
RBK13 Switching between satellites causes Authentication Error
I just bought an RBK13 (router with 2 satellites). I would contact support, but the support site is down! I'm having a problem where our cell phones (Moto G6 and G6 Power) disconnect and display a Au...
dmulder
Jun 14, 2021Tutor
I just tried disabling the SSID broadcast for the 2.4GHz network (another suggestion I found on this forum). So far everything is staying connected. Hard to say if this fixed it, since the disconnects were pretty random.
- dmulderJun 14, 2021Tutor
After about an hour, it started kicking devices off again. Clearly turning off the 2.4GHz SSID broadcast didn't make a difference.
- CrimpOnJun 14, 2021Guru - Experienced User
dmulder wrote:After about an hour, it started kicking devices off again. Clearly turning off the 2.4GHz SSID broadcast didn't make a difference.
Can you please describe more about what happens. Does a phone produce the error only when it changes location?
Can you upload a screen shot of the error message?
(Use the "Browse" button in the lower left of the edit screen. Images placed "in-line" using the Photos icon in the menu bar do not appear to other users until approved by a forum moderator, which can take hours - or days.)
Are any other devices affected besides the two phones?
- dmulderJun 21, 2021Tutor
Turned out it was a problem with one of the satellites. Reseting the satellite fixed the problem (thanks to support for that!)
