rbichan
Nov 24, 2022Aspirant
RBK13 WAN speed
there was a post on Amazon from the Netgear Team that says "The WAN connection supports up to 100Mbps Internet connections, while the WiFi on your LAN side supports up to 1.2 Gbps between devices." ...
CrimpOn
Nov 24, 2022Guru - Experienced User
Can you please copy and paste that comment in the forum? I believe it is simply a typographical error.
The Product Data Sheet for the RBK13 package (K for package) https://www.netgear.com/images/datasheet/orbi/RBK13.pdf states:
Notice the footnote symbol:
Which means that 1.2Gbps is a marketing hype created by adding some theoretical maximum speed numbers to get a ridiculous total. "Full of sound and fury signifying nothing" (Macbeth).
Both router Ethernet ports are 10/100/1000 (i.e. gigabit capable):
