rbichan
Nov 24, 2022Aspirant
RBK13 WAN speed
there was a post on Amazon from the Netgear Team that says "The WAN connection supports up to 100Mbps Internet connections, while the WiFi on your LAN side supports up to 1.2 Gbps between devices." ...
rbichan
Hi CrimpOn
Thanks for the response..
from Amazon Q&A response..
By Netgear Team MANUFACTURER on January 14, 2021
I've also attached the screenshot of Netgear Team response
Thank you.
- CrimpOnNov 24, 2022Guru - Experienced User
Thanks for posting the Amazon question.
If it's on the internet, it must be true. Not!
Easy to test. If the RBK10 router is connected to an Internet Service Provider with a contract greater than 100Mbs, run a Speed Test and see what it reports. If the result is greater than 100Mbs, that would seem illogical. Another method is to look at the Orbi web browser interface (not the 'app'). Open the Advanced Tab and click on Show Statistics in the blue box. It reports the data rate at which the WAN and LAN ports are connected.
I happier with the idea that a well-meaning person made a typo than the alternative that they are "dumber than dirt."
- rbichanNov 24, 2022Aspirant
Hi CrimpOn
Yes, I could do the test, but I have not purchased the item yet, was trying to find out before buying it...
it kinda did not make sense (the statement from Netgear Team), as to why it caps at 100Mbps for WAN
I'm might as well buy it & try it out if not satisfied just return it...
Thanks again !
ps. I like the IF ITS ON THE INTERNET IT MUST BE TRUE line.. from a tv commercial line way back when....lol...
Netgear is like so many companies. They make products for every "price point", from $80 for an RBK13 three pack to $1,500 for an RBKE963 three pack.
The "10 series" is a Dual Band system aimed squarely at the original Google, TP-Link, and other Dual Band products. Costs less to manufacture because it has fewer components (two antennas instead of six (no MIMO), fewer Etherent ports, no Ethernet on the satellite at all, etc.) Uses the single 5GHz channel for both user devices and the backhaul between satellites and router.
I don't think there is much of a "downside" to buying an RBK13. I have spent more taking someone out to dinner and had nothing to show for it besides heartburn. At least you'll get to stream video! Just don't have unrealistic expectations based on the marketing hype.
