rbichan
Nov 24, 2022Aspirant
RBK13 WAN speed
there was a post on Amazon from the Netgear Team that says "The WAN connection supports up to 100Mbps Internet connections, while the WiFi on your LAN side supports up to 1.2 Gbps between devices." ...
rbichan
Hi CrimpOn
Thanks for the response..
from Amazon Q&A response..
By Netgear Team MANUFACTURER on January 14, 2021
I've also attached the screenshot of Netgear Team response
Thank you.
CrimpOn
Nov 24, 2022Guru - Experienced User
Thanks for posting the Amazon question.
If it's on the internet, it must be true. Not!
Easy to test. If the RBK10 router is connected to an Internet Service Provider with a contract greater than 100Mbs, run a Speed Test and see what it reports. If the result is greater than 100Mbs, that would seem illogical. Another method is to look at the Orbi web browser interface (not the 'app'). Open the Advanced Tab and click on Show Statistics in the blue box. It reports the data rate at which the WAN and LAN ports are connected.
I happier with the idea that a well-meaning person made a typo than the alternative that they are "dumber than dirt."
