Snir6590
Oct 20, 2019Aspirant
RBK13 wifi disconnecting problems
Hello guys, in the last few weeks im having some troubles with my ORBI RBK13 System(router is RBR40, and satellites is RBW30). first problem is the wifi keeps disconnecting for 2-5 seconds and t...
ekhalil
Oct 20, 2019Master
This is probably caused by the Satellite connectivity issues introduced in v2.3.1.60 as well as 2.3.5.30. I used to do the following to get around this issue:
- Switch off the both Satellite
- Go to Attached Devices in the web GUI and click on the "Disconnect" button beside both Satellites.
- Turn on the first Satellite and use a paper clip to factory reset the Satellite
- When the Satellite is up after factory reset, press the Sync button on the Satellite and then press Sync button on the Router
- When the Satellite is added after this procedure it should behave correctly.
- Repeat the same (Steps 3-4 above) for the second Satellite.
Good luck!
- Snir6590Oct 20, 2019AspirantThank you for your replay.
I did exactly what you told.me step by step and its still disconnecting every time im playing somthing on my mobile phone, or browsing.
Another idea how to fix it ?
