Snir6590
Oct 20, 2019Aspirant
RBK13 wifi disconnecting problems
Hello guys, in the last few weeks im having some troubles with my ORBI RBK13 System(router is RBR40, and satellites is RBW30). first problem is the wifi keeps disconnecting for 2-5 seconds and t...
ekhalil
Oct 27, 2019Master
Snir6590 wrote:
My brother's computer is connected to the orbi with lan cable and he said that the router is disconnecting randmoly (also with wifi). ......
How do you notice the disconnections on a wired computer? Can you please explain the symptoms you see.
Snir6590
Oct 29, 2019Aspirant
Im still testing it but i have found couple of wierd thing :
I connected my ps4 to the orbi via wifi, and after almost 3 hours i can confirm that there were no disconnections while in my phone i had several disconnections. I also tried my ipad and no disconnections there. Also tried my brother's phone and there are disconnections like in my phone. (We both have one plus devices 7/7 pro running android 10). another thing worth mentioning is that i replaced the sagemcom router with a better model and the disconnections is coming from it directly (it is bridged). do you have any idea what couls Couse the problems ?
- ekhalilOct 29, 2019Master
Snir6590 wrote:
.........while in my phone i had several disconnections. I also tried my ipad and no disconnections there. Also tried my brother's phone and there are disconnections like in my phone........When you say disconnections on the phone, do you mean that the wifi signal will disappear momentarily or only internet will disappear?
