CompServices
Oct 25, 2020Follower
RBK14 satellite won't allow authentication
Good day folks, hope I'm in the right spot here. I have installed no less than a dozen ORbi RBK kits mostly three packs and this one 4 pack. All worked fine except this one issue on the RBK14... AND...
Olaf333
Oct 30, 2020Aspirant
Netgear's new Orbi RBK13 ($229.99) is the company's most affordable Wi-Fi mesh system to date. There's a reason for that: It eschews many of the features that you get with more expensive Orbi systems, most notably aessuccess backhaul band and LAN ports on the satellite nodes. It's a breeze to install and provides age-level parental controls, but you'll have to pay extra for advanced parental controls and network security utilities. Most important, it can't match the feature set and throughput performance of our Editors' Choice, the TP-Link Deco M9 Plus.
