casseiopeian
Jun 17, 2020Aspirant
RBK20 - Been sent a faulty device. How to apply for refund?
I had purchased the Orbi RBK20 AC2200 on consulting with the sales team person on chat in the netgear website on 08/06/2020 and it was delivered the very next day. Right out of the box, I had lots of...
Jun 17, 2020Guru - Experienced User
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
Review the installation guides found on NGs support download site for setup information.
casseiopeian
Jun 18, 2020Aspirant
Tried all settings mentioned with the technical support person on call and nothing improves the performance. There are not heavy equipments or devices next to the router to cause interferance. I negated that by backhauling the router and satellite and the sync is in blue but the speed is still in single digits. The technical suppor person gave up.
- schumakuJun 18, 2020Guru - Experienced User
Have a tiny unmanaged Ethernet Switch - Fast or Gigabit does not matter - to check if the link to both devices making up the wired backhaul connection does have network link LED indications? But anway, in the same room, the wireless backhaul must perform much better.
We need some assistane from Netgear here ... Dustin_V please.
- FURRYe38Jun 18, 2020Guru - Experienced User
- Blanca_OJun 18, 2020NETGEAR Employee Retired
Hi casseiopeian
We'd like to help with getting your case on track. Please allow us to review the support cases you have provided and we'll get back to you the soonest.
Thank you FURRYe38 and schumaku
Blanca
Community Team
- Gr8BharaniAug 24, 2020Aspirant
casseiopeian any further updates?
- casseiopeianAug 26, 2020AspirantNo. The customer support has no intention to help or replace. Now they don’t even respond and after a few days the ticket get closed stating I haven’t responded.
