Daniel_E
Aug 09, 2024Aspirant
RBK20 - Ethernet backhaul with multiple switches
Hello, I have a RBK20 and this network configuration (image). When I try to connect via ethernet backhaul using 3 switches, devices 1 and 2 works perfectly but device 3 keeps rebooting, even if I co...
Daniel_E
Aug 10, 2024Aspirant
Thanks for the reply, the switch 1 is a TP Link TL-SG1016D and switch 2 and 3 are TP Link LS1008G.
What should I be aware to buy a switch compatible with Orbi Backhaul or what brands/model do you recommend?
Thanks a lot.
CrimpOn
Aug 10, 2024Guru - Experienced User
Can you swap switch 2 and switch 3 to see if the problem moves with the switch?
