mkstewartesq
Aug 31, 2020Aspirant
RBK20 - Slower satellite speed (small living space)
Let me start by saying I live in a fairly small space - about 1200 sq. feet, all on one level. I have the router set up in the living room and the satellite in a back room - but there is a hallway running straight form one room to the oher and the router and satellite are almost exactly in line of sight of each other. (I can stand at the door of the back room and see the light on the router. If I moved the router in the back room to the left about five feet, they two devices would literally be in a direct line of sight with each other, no obstructions. Distance about 30 feet.
Connecting to the router, all of my devices hit about 350Mbps. However, if a device connects to the satellite (still a 5Ghz connection), the speed drops to around 200Mbps. While 200Mbps is nothing to sneeze at, I just upgraded my internet speed to enjoy the faster speeds in the backroom where my home officeis located - but Orbi always wants to push that computer to the satellite.
(Edit to clarify situation: if I turn off the satellite, my computer in the backroom connects with the router in the living room (30 feet away) and gets 350Mbps. With the satellite on (computer still in the same location, satellite is about 3 feet away) computer connects to the satellite and max speed is about 200Mbps.
Any ideas?
Thanks,
Mike
- mkstewartesqAspirant
Sorry - typo in title - model is the RBK12 .
- MstrbigMaster
mkstewartesq wrote:Sorry - typo in title - model is the RBK12 .
The RBK12 covers up to 3000 Sq Ft. You have 1200 Sq Ft. Your router may be adequately covering your area. You could try experimenting by moving the satellite to different locations further and closer away.
Check these setting:
Disable Daisy Chain Topology
Enable MU-MIMO
Enable Implicit Beam-forming
Disable Fast Roaming
Enable UPnP
Enable WMM (WiFi Multimedia)
Disable Enable 20/40Mhz Coexistence
Enable MU-MIMO
Enable UPnP
Thank you for all of the suggestions. I changed all of those settings, but no improvement to the satellite. After the reboot, my computer connected to the router and pulled 350Mbps - however, once it eventually shifted to the satellite, speeds dropped back to 215 Mbps.
Mike
