JKHerbert
Jan 25, 2021Tutor
RBK20 +2S disconnects inc wired Pc
Seems it is a common problem to keep the RBK20 from dropping the Internet a couple of times a day. Still working through all the suggestions to try to find the magic bullet. Question - should a PC wir...
vajim
Jan 27, 2021Master
JKHerbert wrote:
Seems it is a common problem to keep the RBK20 from dropping the Internet a couple of times a day. Still working through all the suggestions to try to find the magic bullet. Question - should a PC wired to the Orbi router also lose connection? I ask because my last Netgear router would “lose” wifi but the PC would still be connected. TIA
lets start with the obvious: What Firmware version is currently loaded?
JKHerbert
Jan 29, 2021Tutor
Thanks for replying:
I forced the update V2.6.1.36 when the firmware that the wizard wanted to use (V2.5???) wasn't great.
Really hoping for the answer to my question: if it makes sense that a PC wired to the Orbi router would lose the internet when the wifi fails.
- vajimJan 29, 2021Master
JKHerbert wrote:Thanks for replying:
the 2 connections should be considered separate, however, if the router is not configured correctly it can affect both.
you can check your internet connection by connecting the pc directly to the modem.
- FURRYe38Jan 29, 2021Guru - Experienced User
still discussing firmware and the such.
Thanks
