JKHerbert
Jan 25, 2021Tutor
RBK20 +2S disconnects inc wired Pc
Seems it is a common problem to keep the RBK20 from dropping the Internet a couple of times a day. Still working through all the suggestions to try to find the magic bullet. Question - should a PC wir...
JKHerbert
Jan 29, 2021Tutor
Thanks for replying, FURRYe38
I forced the update to V2.6.1.36.
Modem - I am away from home and have to check this. It is a provided modem system from the ISP which includes home TV as well.
As I said, I have read through and recognize these questions as the common issues. My house is small for the RBK20, about 2500 sq ft, but the modems are on different levels (2nd and the basement) with the router having to be located on the 1st at the other end of the house. Not ideal, but it is an old house. Everything is 30 ft (ish) apart.
I had set it to 1 but recently changed it to 6 (keep tweaking). 48 for the 5 Ghz
Neighbouring wifi that I can see range from 2 - 8 depending on the location in the house, time of day.
As mentioned, I have been tweaking and tried all these with various success. I haven't tried the short vs long preambles. Currently, it seems to "like" the fact that I have turned off the SSID of the 5GHz portion, a suggestion from another post since the Orbi doesn't let me separate the two into two different networks (eg Home2Ghz vs Home 5GHz - I tried using Telnet but that didn't do it.) I have also set up the Guest Network. Still, the network will die at least once of day, but probably more often than that. Is there a log in the system that would show me?
Still wanting to know if it makes sense that the wired PC to the router would lose it's internet connection if the wifi dies?
Jan 29, 2021Guru - Experienced User
Let us know abour your modem.
Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
- vajimJan 29, 2021Master
he's still waiting on answer for this question:
- JKHerbertJan 29, 2021Tutor
Modem - the ISP got back to me to say it is a Calix Fibre Modem but is checking for a model number if that matters. It is locked behind their box in my basement.
Currently, the system is stable. I do want to know if there is a log that tracks that piece, though. One that would say the system was down at ???? am/pm and back up whenever. After turning off the SSID of the 5GHz, I am only aware of the system crashing approximately twice a day. (System = internet and/or wifi)
Thanks again for all the input.
- FURRYe38Jan 29, 2021Guru - Experienced User
Do you notice anything on the top ring of the RBR when this happens?
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
JKHerbert wrote:Modem - the ISP got back to me to say it is a Calix Fibre Modem but is checking for a model number if that matters. It is locked behind their box in my basement.
Modem - Calix P series - 716GE
I have noticed the ring of the satallite go magenta when the signal has been lost, but I have not been checking/tracking the colours of the router. I would be easy to do if that would help.
