JKHerbert
Jan 25, 2021Tutor
RBK20 +2S disconnects inc wired Pc
Seems it is a common problem to keep the RBK20 from dropping the Internet a couple of times a day. Still working through all the suggestions to try to find the magic bullet. Question - should a PC wir...
Feb 02, 2021Guru - Experienced User
Ok, MTU could help I guess. You might ask the ISP if they have a MTU value requirement setting. I know most cable ISPs use 1500, DSL 1492 or 1472. Fiber, not sure.
JKHerbert wrote:Well that didn't work. Wired PC wouldn't connect either. Now talking to Support. Will update if we figure anything out.
PS - Support suggested setting WAN MTU Size to 1468
JKHerbert
Feb 05, 2021Tutor
Support has decided to replace the router. Hopefully, that solves all my problems. AND if not, I will start another thread. ;-)
Thanks, FURRYe38 and vajim, for all your help.
- JKHerbertFeb 08, 2021Tutor
New Orbi RBR20 arrived in 14 hours (kudos to FedEx) and system is working flawlessly. I haven't had to make any adjustments to the default configuration.
Thanks again all for your support.
- vajimFeb 08, 2021Master
JKHerbert wrote:New Orbi RBR20 arrived in 14 hours (kudos to FedEx) and system is working flawlessly. I haven't had to make any adjustments to the default configuration.
Nice work
If you feel your issue is resolved you can mark this thread as such.
Take care
Already did - I think.
