Max_Awesomeness
Jun 23, 2021Aspirant
RBK20 App does not recognize it's connected / Satellite remains solid white only.
RBK20 Just bought and set up router (works great). Problem 1 - App does not recognize it's connected. Keeps saying random things like plug in your cables (they're plugged in), pushes me to redo s...
CrimpOn
Jun 23, 2021Guru - Experienced User
I find the Orbi 'app' almost useless and much prefer using the Orbi web interface to configure routers and sync satellites.
The RBR20 User Manual explains the process:
https://www.downloads.netgear.com/files/GDC/RBK50/Orbi_UM_EN.pdf
- Max_AwesomenessJun 23, 2021Aspirant
Thanks... I've gone down that road but it doesn't help me to fix anything. I tried to download the latest firmware, but it just offers zip files that say they're corrupted when opened. So there's no avenue for setup via the web it seems. No live chat support either. I think I'm going to end up taking it back. I'm not a computer genius and I think you need to be to use this.
- FURRYe38Jun 24, 2021Guru - Experienced User
Are you unpacking the .zip files prior to updating the FW? They have to be unpacked to reveal the actual FW files that need to be send thru the RBR or RBS FW update feature on there web pages using a web browser and PC.
