rebknell
Oct 03, 2020Aspirant
RBK20 bought used - previous owner did not reset
Hello all, I bought an Orbi RBK 20 on eBay used and when I tried to set it up I was stopped at the log in part on the app. I typed the default password in and it said it was wrong. I am assuming...
- Oct 03, 2020
rebknell wrote:So, in order to use this I need a satellite? (as I got to the point where it was searching for one) Won't work without one?
Great, i bought just this unit. They never mentioned in decription it needed this part to work. Sigh.
Works fine without a satellite. You probably missed the cancel option.
rebknell
Mstrbig
Oct 03, 2020Master
- rebknellOct 03, 2020Aspirant
THANK you!
