dominicchengct
Apr 12, 2020Aspirant
RBK20 disconnect when copying many files
I bought the router days ago. I connected two NAS to it. When i try to copy a large amount of files from one to another. The router disconnect from time to time. Can anyone help? Many thanks ...
- Apr 13, 2020
Be sure to make a backup configuration to file for safe keeping. Helps save time if a reset is needed.
Please mark your post as solved so others will know.
Enjoy. :smileywink:
CrimpOn
Apr 12, 2020Guru - Experienced User
dominicchengct wrote:I connected two NAS to it. When i try to copy a large amount of files from one to another. The router disconnect from time to time.
This is an interesting situation.
- How are the NAS connected to Orbi?
Both to the router?
Combination of router and satellite?
Wired, WiFi, or a combination? - What is the meaning of "disconnect"?
The NAS device transfers fail?
Other devices lose internet connection?
Thanks
dominicchengct
Apr 13, 2020Aspirant
Both to the router?
Both to the satellite. If connect to router, router disconect at once.
Yes
Both r wired.
All devices connected to the wifi went disconnected. No more signal.
I think it is due to wifi lost. It transfers awhile then fails
Yes, as mentioned above
Both to the router?
Yes
Both r wired.
