dominicchengct
Apr 12, 2020Aspirant
RBK20 disconnect when copying many files
I bought the router days ago. I connected two NAS to it. When i try to copy a large amount of files from one to another. The router disconnect from time to time. Can anyone help? Many thanks ...
- Apr 13, 2020
Be sure to make a backup configuration to file for safe keeping. Helps save time if a reset is needed.
Please mark your post as solved so others will know.
Enjoy. :smileywink:
Apr 13, 2020Guru - Experienced User
dominicchengct wrote:I bought the router days ago. I connected two NAS to it. When i try to copy a large amount of files from one to another. The router disconnect from time to time. Can anyone help? Many thanks
Dominic
- dominicchengctApr 13, 2020Aspirant
Hi there, i follow your suggestions. And then try copy 3gb and 2gb from one nas to another. Both ok now. Will keep try more. Thanks a lot for yr support amd you really save me from a lot of trouble. Have a good day.- FURRYe38Apr 13, 2020Guru - Experienced User
Enjoy. :smileywink:- dominicchengctApr 14, 2020AspirantNo luck. Disconnection becomes very often later on. Even when i was doing nothing. I restore the setting manully but issue still persists. Help.
