dominicchengct
Apr 12, 2020Aspirant
RBK20 disconnect when copying many files
I bought the router days ago. I connected two NAS to it. When i try to copy a large amount of files from one to another. The router disconnect from time to time. Can anyone help? Many thanks ...
- Apr 13, 2020
Be sure to make a backup configuration to file for safe keeping. Helps save time if a reset is needed.
Please mark your post as solved so others will know.
Enjoy. :smileywink:
Apr 13, 2020Guru - Experienced User
dominicchengct wrote:I bought the router days ago. I connected two NAS to it. When i try to copy a large amount of files from one to another. The router disconnect from time to time. Can anyone help? Many thanks
Dominic
dominicchengct
Apr 13, 2020Aspirant
Hi there, i follow your suggestions. And then try copy 3gb and 2gb from one nas to another. Both ok now. Will keep try more. Thanks a lot for yr support amd you really save me from a lot of trouble. Have a good day.
- FURRYe38Apr 13, 2020Guru - Experienced User
Enjoy. :smileywink:- dominicchengctApr 14, 2020AspirantNo luck. Disconnection becomes very often later on. Even when i was doing nothing. I restore the setting manully but issue still persists. Help.
- FURRYe38Apr 14, 2020Guru - Experienced User
Has a factory reset and setup from scratch been performed since last FW update? Might try this.
Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?And if you turn OFF The RBS and connect all devices to the RBR only, does the system still fail when copy files are performed?
