dominicchengct's avatar
Apr 12, 2020
RBK20 disconnect when copying many files
I bought the router days ago. I connected two NAS to it. When i try to copy a large amount of files from one to another.   The router disconnect from time to time.  Can anyone help?  Many thanks   ...
  • FURRYe38's avatar
    Be sure to make a backup configuration to file for safe keeping. Helps save time if a reset is needed.
    Please mark your post as solved so others will know.
    Enjoy. :smileywink:
