PJguy
Feb 06, 2021Follower
Rbk20 Ethernet backhaul stopped working
For the last two or three firmware versions Ethernet backhaul has stopped working. I’m currently on the latest 2.6.2.104 for both the rbr and rbs. It has always gone through a single switch. I’ve Had ...
Feb 06, 2021Guru - Experienced User
You can downgrade the firmware if its causing an issue.
What I'd recommend first is a factory reset and reinstall.
Are the satellites on the same firmware version?
