2hannahkim
Sep 01, 2020Aspirant
Rbk20 firmware doesn’t update from 2.3.5.30
I’m frustrated as I’m trying to resolve a security issue raised by Netgears own network scan. It said I didn’t have the latest firmware. I used to the orbi app to check for updates. I got an error....
- Sep 03, 2020
Wire connect a PC to the router and factory reset the router using the back push pin button. Hold it in for 15 seconds then let go. Wait for the WHITE led to slowly pulsate on top of the RBR, then log in to orbilogin.com using a web browser and walk thru the setup wizard. This time write down all important information for safe keeping later on.
2hannahkim wrote:As i stated before.. i can't reset my admin password, because i can't remember the answer to my 2 security questions. There are no instructions for this in the manual.
Can anyone help?
2hannahkim
Sep 02, 2020Aspirant
Could you be more specific as to which documentation? I checked the ones I could, I haven’t been successful yet.
Mstrbig
Sep 02, 2020Master
Go to https://www.netgear.com/support/download/
Enter your RBK20
On the right will be the files needed to download, which are
RBR20 Firmware Version 2.5.1.16 and RBS20 Firmware Version 2.5.1.16
