dillonykyang
May 09, 2019Follower
RBK20 phone cannot connect to sattelite slow speed
Hi all, I have recently installed the ac2200 triband router. I have the base installed on my second floor where my main living area is - and 2 sattelites on my first and third floor. However,...
May 09, 2019Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
What speeds do you pay for UP and DOWN from your ISP?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Is Daisy Chain enabled? Try disabling the following and see:
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Has a factoy reset been performed and setup from scratch since FW was updated?
