HAKW02
Jun 05, 2020Aspirant
rbk20 SUDDENTLY failed to USE 1000MBS, instead it stays on 100mbs only
I bought this orbi rbk20 with 7 months ago, used to be able to support my 1gb pc network, but since a week ago, i dont know why it it stayed on 100mbs on all of my pc incluuding desktop and laptop. h...
HAKW02
more info,
1 wifi is fine, can go very fast speed
2 same cable, havent upgraded anything including cables
3 if bypass the orbi, connect directly to the modem, works also fine
Jun 05, 2020Guru - Experienced User
HAKW02 wrote:more info,
1 wifi is fine, can go very fast speed---faster than the 100mbps?
2 same cable, havent upgraded anything including cables----again, try checking the cables, they've had issues before.
3 if bypass the orbi, connect directly to the modem, works also fine---"works fine" what speeds do you get? works fine doesn't tell us much.
i attached the statistics that I'd asked for so you can see what we're looking for.
