Rusty27
Jul 23, 2019Tutor
RBK20 Troubleshooting internet slowness / QOS
How is everyone dealing with troubleshooting devices that are utilizing all your internet bandwidth? New Orbi customer and I'm very happy with LAN connection speeds and performance but where I'm lo...
Jul 23, 2019Guru - Experienced User
What ISP speeds do you pay for UP and Down?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
QoS is mostly behind the scenes and is automatic.
I have about 30 devices on my system. A few streamers and two gamers...no issues.
Rusty27 wrote:How is everyone dealing with troubleshooting devices that are utilizing all your internet bandwidth? New Orbi customer and I'm very happy with LAN connection speeds and performance but where I'm located I'm limited on internet connection speeds. That said, with 50+/- devices on my network, not having any visibility or QOS with Orbi seems mind blowing? How is everyone else dealing with these limitations? I was hoping the built in intelegence would make living without these features worth the mesh WiFi and coverage.
Rusty27
Jul 23, 2019Tutor
I'm really only concerned with two laptops and they are hardwired and not using wireless. Everything else on my network, I'm not as concerned with. Regular QOS seems to be working as designed.
What Firmware is currently loaded? v. 2.3.5.26
What is the Mfr and model# of the ISP modem the NG router is connected too? RBK23 kit, RBR20 Router w/ 2 satelites.
What ISP speeds do you pay for UP and Down? DSL 2 mbs up / 24 mbs down (best I can buy).
What is the size of your home? Sq Ft? 2000 sq ft but in this case, I'm hardwired where I need QOS
Any Wifi Neighbors near by? If so, how many? Using Auto and having no issues on wifi. No neighbors in 200+ yards of me.
Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings. Thanks. I'll try this.
Thanks. I'll try these as well.
QoS is mostly behind the scenes and is automatic. Agree but I'm also use to have options to give specific devices higher priority. I'm also coming from a DD-WRT. Found there is a hidden QOS page in Orbi. http://192.168.1.1/QOS_rule.htm Anyone been able to use it? Appear it is not configurable.
