Rusty27
Jul 23, 2019Tutor
RBK20 Troubleshooting internet slowness / QOS
How is everyone dealing with troubleshooting devices that are utilizing all your internet bandwidth? New Orbi customer and I'm very happy with LAN connection speeds and performance but where I'm lo...
Rusty27
Jul 23, 2019Tutor
I'm really only concerned with two laptops and they are hardwired and not using wireless. Everything else on my network, I'm not as concerned with. Regular QOS seems to be working as designed.
What Firmware is currently loaded? v. 2.3.5.26
What is the Mfr and model# of the ISP modem the NG router is connected too? RBK23 kit, RBR20 Router w/ 2 satelites.
What ISP speeds do you pay for UP and Down? DSL 2 mbs up / 24 mbs down (best I can buy).
What is the size of your home? Sq Ft? 2000 sq ft but in this case, I'm hardwired where I need QOS
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Any Wifi Neighbors near by? If so, how many? Using Auto and having no issues on wifi. No neighbors in 200+ yards of me.
Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings. Thanks. I'll try this.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Thanks. I'll try these as well.
QoS is mostly behind the scenes and is automatic. Agree but I'm also use to have options to give specific devices higher priority. I'm also coming from a DD-WRT. Found there is a hidden QOS page in Orbi. http://192.168.1.1/QOS_rule.htm Anyone been able to use it? Appear it is not configurable.
Jul 23, 2019Guru - Experienced User
What is the Mfr and model# of the ISP modem the NG router is connected too? This would be the modem that you get from your ISP, not the Orbi system.
You can't configure any hidden menus.
What seems to be the problem with these two laptops when wire connected to the Orbi RBR?
- Rusty27Jul 23, 2019Tutor
Yeah. I have a Windstream T3200 ADSL modem. I've looked for QOS options on it but not found anything.
Good to know about the hidden menus.
My issue is I work from home and when kids are home streaming and playing on their devices, it inteferres with my system. Normally all works fine. Like I said in other post, I'm coming from DD-WRT, which is highly customizable and has QOS options. If I'm not able to do any QOS or priortization with Orbi, my two options right now is to 1) put Orbi in bridge mode and put my old LinkSys DD-WRT router back in place or 2) return Orbi system and find another solution Nighthawk, etc.....
- FURRYe38Jul 23, 2019Guru - Experienced User
Is the ISP modem bridged?
You may try the Prior router back on line and set the Orbi for AP mode and see.
ISP modem is not in bridge mode. Not sure there is a option on this particular modem. Or at least it isn't a obvious option.
Thought about trying Orbi in AP mode but it really defeats my goal of simplifying my setup. :(
- CrimpOnJul 23, 2019Guru - Experienced User
FURRYe38 wrote:You can't configure any hidden menus.
Indeed. A bit nasty of Netgear to expose a web page that clearly offers the ability to "Add" a new QOS rule, but then not accept one. Especially since one of the rule types is for LAN ports 1, 2, 3. Wonder what their reasoning was to allow "debug.htm" to make changes to the Orbi, but not QOS_rule.htm.
Has my memory failed (again), or was there once a "QOS" menu entry on the Orbi web interface?
Orbi's UI takes from a long standing UI template that mostly is a all around UI fitment for there routers. So depending upon each router model and what NG desides to implement for features for each router model, NG just hids some of the features that other router models won't support. So QoS that is hidden on Orbi maybe seen on other model routers that do support it.
CrimpOn wrote:Has my memory failed (again), or was there once a "QOS" menu entry on the Orbi web interface?
