Rusty27
Jul 23, 2019Tutor
RBK20 Troubleshooting internet slowness / QOS
How is everyone dealing with troubleshooting devices that are utilizing all your internet bandwidth? New Orbi customer and I'm very happy with LAN connection speeds and performance but where I'm lo...
Jul 23, 2019Guru - Experienced User
Your other consideration is that your limited by your ISP speed as well. Others having a similar kind of network device capacity also have higher ISP speeds and bandwith as well. It's possible that your ISP speeds maybe a bit too low for the Orbi to handle and manage with all the devices that you have connected and doing streaming and such while all online together. The ISP speeds maybe a bottle neck. We understand that this is what you can get from your ISP.
I would try the WRT router back in place and configure the Orbi system for AP mode and see if these problems still appear or not.
