Marlboro123
May 14, 2020Tutor
RBK20 unable to connect to Unifi (Malaysia)
Hi, I just received my RBK20 and had it setup up bae on Melvin's post (https://melvinchng.github.io/orbi/setup.html#step-8a-setup-vlan-id-unifi-user). After setting it up, the RBR20 is not ab...
Marlboro123
May 15, 2020Tutor
someone mentioned older firmware was workable.
can I downgrade mr RBR20 firmware from V2.5.1.16 to few versions back ?
say... v2.1.2.18 ?
will this brick the router ??
Marlboro123
May 17, 2020Tutor
Tried reverting the firmware to v2.1.2.18 but still can't connect to ISP
Any help would be appreciated
- lhowardJun 30, 2020AspirantI have all the same issues. I’ve tried using the app and web to access the router, which I can do fine. I can see the satellites. My unifi login and password are correct. I updated the firmware to v2.5.1.16 and added the vlan tag. Still no internet connection. I tried adding a fixed dns address. I can plug my old TM router in and get internet straight away. I can’t work out what to do next. Any advice is appreciated.
