Marlboro123
May 14, 2020Tutor
RBK20 unable to connect to Unifi (Malaysia)
Hi, I just received my RBK20 and had it setup up bae on Melvin's post (https://melvinchng.github.io/orbi/setup.html#step-8a-setup-vlan-id-unifi-user). After setting it up, the RBR20 is not ab...
Marlboro123
May 17, 2020Tutor
Tried reverting the firmware to v2.1.2.18 but still can't connect to ISP
Any help would be appreciated
lhoward
Jun 30, 2020Aspirant
I have all the same issues. I’ve tried using the app and web to access the router, which I can do fine. I can see the satellites. My unifi login and password are correct. I updated the firmware to v2.5.1.16 and added the vlan tag. Still no internet connection. I tried adding a fixed dns address. I can plug my old TM router in and get internet straight away. I can’t work out what to do next. Any advice is appreciated.
