mackitten
Dec 18, 2018Tutor
RBK20 vs RBK33
Hello,
I finalyl settled on trying an Orbi for our 2,500+ some sqft home.
I ordered this Sunday night from B&H for which I thought was a good price. It has the RBR20 and one wall plug
ekhalil
Dec 18, 2018Master
The RBK20 consists of one Router (RBR20) and a Satellite (RBS20). The router has one internet port and 2 LAN ports. Satellite has 2 LAN ports.
The RBK33 consists of Router (RBR40) and 2 wall plugs (RBW30). Router has one internet port and 4 LAN ports. The wall plugs (Satellites) have no LAN ports, they are just wall plugs.
- mackittenDec 19, 2018Tutor
Thanks
actually looks like the kit I got is called rbk20w and has one rbr20 and one wall satellite
that arrived but but the difference in cost for the rbk33 is only $44 plus shopping the rbk20w back
just wlndering if the performance of the 20 vs 40 is any difference in signal ? I know I get another satelittle but will the 40 provide better performance
I just trying to figure if it’s a better choice to spend them extra $$ for the rbk33
