JordonMusser
Jun 23, 2021Aspirant
RBK20 WiFi cant connect to Wired devices
I am trying to ping a wired connection with a device on the WiFi and it doesn't work. I am using the ORBI in AP mode, with a FIOS router for DHCP. Everything else works fine, I just can't con...
Jun 23, 2021Guru - Experienced User
Is these devices connected to the RBR, RBS or do you have the wifi running on the ISP router and devices connected there?
JordonMusser
Wired: I wired it to both the switch (connected to router) and also directly to the RBR with no change.
Wireless: I am believe Ive been connected to the RBR and BRS with same issue.
