RGOLD
Feb 28, 2019Tutor
RBK20/22 Owners - Do not upgrade to V2.3.0.28
Firmware V2.3.0.28 has issue with connecting devices to sattelite. All devices will stay connected to the router. Had to revert back to firmware V2.2.1.210.
- Mar 01, 2019
UPDATE:
Moving the 2.4GHZ from busy channel 1 to channel 11 resolved the issue, now I have half of my 18 devices connecting via the satellite as it use to before. I never bother to do a factory reset but if I did in this case, it will probably auto chose the less busy channel and the problem will also be solved.
RGOLD
Feb 28, 2019Tutor
Firmware 2.2.1.210: 6 devices will connect to Sattelite 5 - 10 minutes after reboot. laptop will connect when moving closer to the sattelite.
Firmware 2.3.0.28: Only 1 device will connect to Sattelite 30 minutes after reboot the rest will stay connected to the router. Moving my laptop close to the sattelite will not make any diffrence, it will stay connected to the router eventough the router signal is weaker.
The only reason I decided to upgrade from 2.2.1.210 is the DHCP issue where I get 2 devices with same IP address...
Feb 28, 2019Guru - Experienced User
How did you update FW, manuallyl or use the AutoUpdate feature?
Did you try a factory reset and setup from scratch after loading v28?
