RGOLD
Feb 28, 2019Tutor
RBK20/22 Owners - Do not upgrade to V2.3.0.28
Firmware V2.3.0.28 has issue with connecting devices to sattelite. All devices will stay connected to the router. Had to revert back to firmware V2.2.1.210.
- Mar 01, 2019
UPDATE:
Moving the 2.4GHZ from busy channel 1 to channel 11 resolved the issue, now I have half of my 18 devices connecting via the satellite as it use to before. I never bother to do a factory reset but if I did in this case, it will probably auto chose the less busy channel and the problem will also be solved.
ekhalil
Mar 01, 2019Master
SeaMonkey80 wrote:
Do you have the Fast Roaming setting turned on? If not, try enabling it. I have seen my devices switch to the satellites easier with this setting enabled.
Fast Roaming (IEEE 802.11r) is more useful and improves roaming time when using WPA2 Enterprise Security (which is not supported in Orbi).
With WPA2 Personal Security (used in Orbi) Fast Roaming improves the process of establishing the new encryption key between the AP that the device is roaming to and the mobile device, which -somewhat- improves the roaming speed for devices supporting Fast Roaming, BUT having Fast Roaming enabled can cause packet drops for old devices that do not support Fast Roaming (IEEE 802.11r).
RGOLD
Mar 01, 2019Tutor
UPDATE:
- FURRYe38Mar 02, 2019Guru - Experienced User
Sounds like you found the problem. Yes busy surroudings can cause problems. Why manual channel selection is good as well.
Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Glad it's not the FW.
Enjoy. :smileywink:
RGOLD wrote:
UPDATE:
- BullyterrierMar 03, 2019Star
Just to say my 43 when manually updated to this firmware had a number of settings reset. Firstly for WIFI my previous manually set 2.4 channel was reset to auto and secondly fast roaming was reset to off. Daisy chain was also reset to on.
This choice (undocumented) to reset certain saved parameters will no doubt causes a number of these type of issues across the less tech savvy part of the installed base.
- FURRYe38Mar 03, 2019Guru - Experienced User
I would do a factory reset on the entire system after the update. Setup from scratch. After it's all set up, do a save config to file under Advanced Tab/Advanced Settings/Backup. Keep this save config file for future use.
