Adl9128
Oct 02, 2019Aspirant
RBK20W Power Supply - Moving US to Europe
Hi, I have seen other posts asking if the Orbi is compatible in Europe and the general answer has been that the power supply is 100-240V and would be fine. My issue is that the label on my Orbi pow...
michaelkenward
Oct 03, 2019Guru - Experienced User
Adl9128 wrote:
Hi,
I have seen other posts asking if the Orbi is compatible in Europe and the general answer has been that the power supply is 100-240V and would be fine. My issue is that the label on my Orbi power supply only lists 100-120V.
I have tried about half a dozen of those "120 volt" adapters on 240 volts. Netgear and Arlo have both shipped things directly to me from the USA. (Arlo things can still turn up with Netgear adapters.) Not one has gone bang.
Just buy an adapter that accepts the US plug.
If it does go phut – it won't hurt the Orbi, especially if you try it before connecting it to the router – then any generic adapter will work as long as it has the right specs.
You may have problems using a US device in Europe because Netgear locks "NAS" stuff to the wifi bands that are legal in the USA. If you want to use European bands you may have to delve into Telnet territory. But you can clear that hurdle when you reach it.
