xpspiq
Jun 18, 2020Aspirant
RBK20W with Extender ????
We are considering purchasing an ORBI modem and add an Outdoor Orbi Extender to provide wifi to a building ~250 feet away.
The base home is a split level - 3BR of about 2500' living area.
Looking for the most inexpensive ORBI system that would allow the Extender to work well...
Wondering if the RBK20W would provide what we need.
Would appreciate guidance before purchase.
moorerandyj@gmail.com
Yes RBWs will work however these are indoor only. If you want something out doors, the RBS50Y is the outdoor satellite.
- xpspiqAspirant
Thanks.
Yes. We are planning to purchase the outdoor Orbi Extender but wanted to make sure we paired it with an adequate base system to ensure its effectiveness...- we were trying to stay as economic as possible and still be able to connect effectively with the outdoor building.
xpspiq wrote:We are considering purchasing an ORBI modem and add an Outdoor Orbi Extender to provide wifi to a building ~250 feet away.
An Orbi RBS50Y is indeed rated for "outdoor" use, but is unlikely to solve the problem. That distance is simply too far for an ordinary WiFi access point to provide a strong signal, particularly if it has to penetrate the building wall in addition to the distance.
How to provide WiFi to a separate building is a frequent question. The "A" option is to install a Cat6 ethernet cable between the buildings. A cable provides the highest connection rate and is totally impervious to trees, weather, etc. When this is impractical (as it often is), the "B" answer is to install a "point to point wireless bridge". Almost every manufacturer sells these. How about looking at the user reviews for products such as the Ubiquiti NanoStation: https://www.amazon.com/NanoStation-NS-5ACL-US-802-11ac-Airmax-Radio/dp/B07GPQKLXW/ref=sr_1_6?dchild=1&keywords=ubiquity+nanostation+loco+ac&qid=1592525107&sr=8-6
They make at least a dozen different models, some with higher throughput (some with less but maybe "enough").
Those product reviews will illustrate how others solved the issue and will most likely point toward similar products from other vendors.
There are some cool YouTube videos showing how to set up point-to-point bridges.
Since these gizmos are distance rated in terms of "kilometers", there is a good chance they can be deployed inside the main house and distant building.
Good Luck
- xpspiqAspirant
Thanks for the point to point suggestion.
So do I then not need the Extender and replace that with my new Orbi Modem in the remote building? I have very limited experience beyond just setting up an Orbi and satellites in my stand alone home.
I don't understand how the remote building gets wifi access with the point to point set up ...thanks much ..
