Milk_my_duds's avatar
Milk_my_duds
Follower
May 13, 2018
RBK22 - Can you add additional satellite?
I bought RBK22 from Costco.  It comes with the main router and 1 RBS20 satellite.
I am trying to get another indoor satellite to improve wifi signals in specific corners of the house.   However, I am not able to find "RBS20" satellite on Amazon.
Does RBK22 support additional satellites, or it is hard coded to work with only 1 satellite?
Thanks.
  • Yes it will work with any orbi satellite you could use a RBW30 if you wanted to with your system.
    DarrenM
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    DarrenM
