Trpl4
Apr 06, 2019Aspirant
RBK22 - Cannot connect to the Internet
I just purchased the RBK22 tri band router. It is replacing my AirPort Extreme (Time Capsule). I have the Time Capsule’s WiFi off and want to use it as a backup disk like before. I have it connected ...
Trpl4
The FW is 2.3.1.44 for the Orbi router. The manufacturer for the modem is Cisco, model number DPC3008
I turned the wifi off on the Airport router per the directions from Apple. So it shouldn’t be sending out a WiFi signal. I have the Ethernet cable from the main Orbi plugged into one of the Ethernet ports on the Airport. I initially had it plugged in the LAN port on the Airport and I couldn’t see it so I tried one of the other ports and it works. Thanks for the quick reply.
I really want to keep the Airport solely for wireless backups and according to Apple it can be.
Apr 06, 2019Guru - Experienced User
I believe the routing function on the TC needs to be disabled.
I would refer to Apples support information regarding this on how to get there device working with a different router. They should have this information.
