bobby071's avatar
bobby071
rbk22 -flashing white light
I just bought a new orbi rbk22 system. The router keeps flashing white forever..
  • The customer service 24/7 number is also not working... Really I might just return this product.
  • FURRYe38's avatar
    Are you walking thru the set up wizard after setting up the router?
    What Mfr and model# is the ISP modem the router is connected to?
    What FW is the router using currently?
    • bobby071's avatar
      bobby071
      My firmware is up to date. It is attached to verizon fios modem.
  • FURRYe38's avatar
    What model# is the ISP modem the router is connected to?
    What FW version is the router using currently?
    Factory reset the router and walk thru the set up wizard. Use a wired PC connected to the router.
