RyanE6
Apr 18, 2020Tutor
RBK22 Existing Modem/Router, Switches etc
Hello, I just purchased the RBK22 from Costco. Everything is hooked up and running after reading through a few posts on here but I have questions. Current Configuration: Netgear c7000v2 (modem/rou...
- Apr 20, 2020
Yes, thats the setting. Changed to NO and this puts the modem in to modem only mode. Then use the RBR in router mode.
To access the modems web page, you'll need to access it via 192.168.100.1 I believe when it's in modem only mode. Since the router portion is disabled, the 192.168.0.1 no longer works.
RyanE6
Apr 18, 2020Tutor
I can reach each interface through my web browser on my PC but why would the Orbi app itself direct me to the other router?
The Orbi has newer technology, faster speeds and a better application. I would like to think it's better or at least give it a chance. Should I move everything over, would I need to change the c7000v2 to "router mode" "no" and change Orbi back to Router Mode from AP, correct?
CrimpOn
Apr 18, 2020Guru - Experienced User
RyanE6 wrote:
I can reach each interface through my web browser on my PC but why would the Orbi app itself direct me to the other router? I have no answer for this.
I would change the Orbi back to router first, then attempt to change the C7000. Once again, I am no expert, but I am puzzled that I cannot find any obvious way to put this device into "bridge" or "passthrough" mode.
https://www.downloads.netgear.com/files/GDC/C7000/C7000_Comcast_UM_27apr15.pdf
