RyanE6's avatar
RyanE6
Tutor
Apr 18, 2020
RBK22 Existing Modem/Router, Switches etc
Hello, I just purchased the RBK22 from Costco. Everything is hooked up and running after reading through a few posts on here but I have questions. Current Configuration: Netgear c7000v2 (modem/rou...
  • FURRYe38's avatar
    Yes, thats the setting. Changed to NO and this puts the modem in to modem only mode. Then use the RBR in router mode.
    To access the modems web page, you'll need to access it via 192.168.100.1 I believe when it's in modem only mode. Since the router portion is disabled, the 192.168.0.1 no longer works.
