RyanE6
Apr 18, 2020Tutor
RBK22 Existing Modem/Router, Switches etc
Hello, I just purchased the RBK22 from Costco. Everything is hooked up and running after reading through a few posts on here but I have questions. Current Configuration: Netgear c7000v2 (modem/rou...
- Apr 20, 2020
Yes, thats the setting. Changed to NO and this puts the modem in to modem only mode. Then use the RBR in router mode.
To access the modems web page, you'll need to access it via 192.168.100.1 I believe when it's in modem only mode. Since the router portion is disabled, the 192.168.0.1 no longer works.
RyanE6
Apr 20, 2020Tutor
There is a setting: Router Mode (yes or no), by selecting no, this enabled modem only mode and I enabled router mode on the Orbi. I don't touch any of the NAT settings and everything seems to be up and running. All of my devices are connected wired and wirelessly and the Orbi app is functioning as it should.
The only issue I've run into is, I don't know how to access the modem settings on the c7000v2 now since the IP address has changed.
Apr 20, 2020Guru - Experienced User
