bent57
Apr 06, 2022Tutor
rbk22(rbr20 router and rbs20 satellite) to be used as access point
Hi. I plan to upgrade to wifi6(any brand including orbi6 ). I still want to use my existing router rbk22(rbr20 router and rbs20 satellite). I have 3 questions: 1. If I use rbr20 as access point, wil...
Apr 06, 2022Guru - Experienced User
1. If I use rbr20 as access point, will it automatically include rbs20 as satellite? Is there any extra configuration needed?----if they're already setup and you didn't factory reset, then should auto connect when you switch it to AP mode. If you factory reset it, then you'll need to re-add them as you would a new system.
2. If I use rbr20 as access point, does it need to be wired to the new router permanently?----yes. Or can the access point be connected wirelessly from the new router?---No you can't connect it wirelessly to the new router.
3. If I use rbr20 as access point, can I access wifi from both the new router and the access point. Is the wifi SSID name different from each? Can I use the same SSID for both?----Can you use the same ssid? sure. Will it roam as if it was a single mesh system? No. it won't. They'll roam between that same systems (router/satellites) parts but not between the 2 systems efficiently. I'd recommend using a different ssid and making sure you have the wifi channels separated to prevent interference.
Thanks in advance.
- bent57Apr 06, 2022TutorThanks for the confirmation but I still need to ask this for emphasis: So there is no way rbr20 can be used as a wireless repeater?
- CrimpOnApr 06, 2022Guru - Experienced User
bent57 wrote:
Thanks for the confirmation but I still need to ask this for emphasis: So there is no way rbr20 can be used as a wireless repeater?No. Sorry. Kind of sad that a $40 WiFi repeater (of any brand) is capable of things that an expensive router isn't.
- bent57Apr 07, 2022Tutor
Got it! Thanks.
