arpasquill
Jan 22, 2020Aspirant
RBK23 - sudden solid magenta
Hi everyone, I recently purchased the Orbi RBK23 to solve some wifi issues at home and it has been absolutley fantastic! However, sadly when I came downstairs this morning, the ring on the ro...
Jan 22, 2020Guru - Experienced User
Power OFF the ISP modem and RBR for 30 seconds. Then power ON the modem. Let it sync. Then power ON the RBR. Does the RBR top ring LED turn OFF or still remain PINK?
Is the Orbi system operating in Router or AP mode?
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
- arpasquillJan 22, 2020Aspirant
Thanks I'll give this all a go. As I mentioned, I've had absolutely no problems until this morning which makes it all a little more annoying!
- FURRYe38Jan 22, 2020Guru - Experienced User
Let us know how it goes...
