Imulji
Mar 11, 2019Guide
RBK23 and separating 2.4/5G
Hi there! I've tried to seperate the 2.4/5 GHz networks as has been posted via telnet but this doesn't seem to work with the RBK23. Thought I'd post on this specific equipment to see if anyone has ...
ekhalil
Mar 13, 2019Master
Strange that the same commands do not work for RBR20 routers. There must be different interface mapping in the RBR20/40 compared to the RBR50?
Please print the following two telnet commands and let's compare it with the output below from my RBR50.
root@RBR50:/# cat /tmp/netscan_if_conf
eth1 wired 1
ath0 2G 0
ath01 satellite 0
ath1 5G 0
ath2 satellite 0
ath02 2G-GUEST 0
ath11 5G-GUEST 0
eth0 wired 2
root@RBR50:/# cat /tmp/wifi_topology
NORMAL:AP:wifi0:ath0:@wifi-iface[0]:wl
BACKHAUL:AP:wifi0:ath01:@wifi-iface[1]:wlg_ap_bh
NORMAL:AP:wifi1:ath1:@wifi-iface[2]:wla
GUEST:AP:wifi0:ath02:@wifi-iface[3]:wlg1
GUEST:AP:wifi1:ath11:@wifi-iface[4]:wla1
BACKHAUL:AP:wifi2:ath2:@wifi-iface[5]:wla_2nd_ap_bh
root@RBR50:/#
Imulji
Mar 13, 2019Guide
Thank you!
Here we go just to show that changing the SSID sticks via Telnet:
root@RBR20:/#
root@RBR20:/# config get wl_ssid
M NETWORK
root@RBR20:/#
root@RBR20:/# config get wla_ssid
M NETWORK
root@RBR20:/#
root@RBR20:/# config set wla_ssid="M NETWORK 5"
root@RBR20:/#
root@RBR20:/# config commit
root@RBR20:/#
M NETWORK 5
root@RBR20:/#
M NETWORK
oot@RBR20:/#
root@RBR20:/# reboot
root@RBR20:/#
root@RBR20:/#
Connection to host lost.
SO based on this it has been changed.
Here we go:
root@RBR20:/# cat /tmp/netscan_if_conf
eth1 wired 1
ath0 2G 0
ath01 satellite 0
ath2 5G 0
ath11 satellite 0
ath02 2G-GUEST 0
ath21 5G-GUEST 0
eth0 wired 2
ath1 5G 0
ath12 5G-GUEST 0
root@RBR20:/# cat /tmp/wifi_topology
BACKHAUL:AP:wifi1:ath11:@wifi-iface[3]:wla_ap_bh
GUEST:AP:wifi0:ath02:@wifi-iface[4]:wlg1
GUEST:AP:wifi1:ath12:@wifi-iface[5]:wla1
NORMAL:AP:wifi2:ath2:@wifi-iface[6]:wla_2nd
GUEST:AP:wifi2:ath21:@wifi-iface[7]:wla1_2nd
I should say I HAVE NO IDEA what any of that means!
THanks again ekhalil
- ImuljiMar 13, 2019Guide
I should also say, that even though i do the config set and config commit and run the config get to confirm the change in SSID name, after I reboot and run the config get, it reverts back to the original SSID.
It seems like the RBK23 somehow doesn't save the new SSID name?
- ekhalilMar 13, 2019Master
Thanks for the information.
It seems that RBR20 is using an extra network called wla_2nd.
Can you please print all SSID's using the following command:
- nvram show | grep ssid
ekhalil Thanks again for your help.
root@RBR20:/# nvram show | grep ssid
bridge_wl_ssid=NETGEAR-Bridge
wla_ssid=M NETWORK
wla_2nd_ul_bssid=
wlg_ext_ssid=
wlg_ul_bssid=
wla_ul_bssid=
wlg_ap_bh_ssid=NETGEAR_ORBI_hidden78
wla_ap_bh_ssid=NETGEAR_ORBI_hidden78
wan_brig_ssid1=0
wan_brig_ssid2=0
endis_ssid_broadcast=1
wla_sta_ssid=NETGEAR_ORBI_hidden78
wlg_sta_ssid=NETGEAR_ORBI_hidden78
wla_2nd_ssid=MULJI NETWORK
wl_ssid=M NETWORK
wla_2nd_endis_ssid_broadcast=1
wlg1_ssid=M NETWORK-Guest
wla1_ssid=M NETWORK-Guest
wla1_2nd_ssid=M NETWORK-Guest
wlg_arlo_ssid=arlo_S_EXL5lTgTltlXLg5SEEbTlOhD
