Imulji
Mar 11, 2019Guide
RBK23 and separating 2.4/5G
Hi there! I've tried to seperate the 2.4/5 GHz networks as has been posted via telnet but this doesn't seem to work with the RBK23. Thought I'd post on this specific equipment to see if anyone has ...
May 23, 2019Guru - Experienced User
This is not a problem with Orbi. This is an intended design of MESH and Smart Connect and having a single SSID. This all started with Smart Connect. The single SSID works for most everyone. For those having setup issues with there devices, You can disable the either SSID from being broadcast if your having problems setting up 2.4Ghz devices with Orbi Under Advanced Tab/Advanced Settings/Wireless.
I've never has any issues with my Macs connect to 5Ghz with Orbi. Ever. Mac Book Pro 2008 and Mac Mini 2012. I've been using Smart Connect since it first appeared. If users have issues with Apple products then would need to post about it and lets troubleshoot, and or ask Apple of support and help as well. Handling of WiFi signals is done at the device, not the Orbi.
Msw70 wrote:
Sensei: Just search the internet to see the myriad different reasons this is a problem or read the other posts on this topic in these community pages. Most have to do with getting stuck in 2.4 band and problems for Macs, which don’t switch automatically back to 5ghz if they get assigned to 2.4.
Msw70
May 24, 2019Tutor
I understand how it works and that it works as designed. That doesn’t mean it isn’t a problem for many, even if it isn’t a problem for you. There wouldn’t be all these threads if it were as seamless for everyone as it seems to be for you. Congratulations on that, but it happens to be a deal breaker for me.
- FURRYe38May 26, 2019Guru - Experienced User
Maybe not for you. However NG does make it easier to get some 2.4Ghz only devices setup by giving users the ability to temporarily disable the 5Ghz SSID. MESH may not be for everyone. Again MESH is based mostly on the use of Smart Connect and having a signal SSID. If separate SSIDs were ment to be in MESH then they would included support for it or it wouldn't be MESH. For users that need sepearate SSIDs then users should look else where and not expect a product that already was designed for single SSID to be changed to having separate SSIDs. Most of the issues seen are with 2.4Ghz Mfrs and how they develop and design there products wih out any regard to current and future use of dual and tri band systems using a single SSID. If these Mfr would step up and get there products working and have more compatibility, users wouldn't have as much issues with using MESH systems and signal SSID.
Good Luck.
Msw70 wrote:I understand how it works and that it works as designed. That doesn’t mean it isn’t a problem for many, even if it isn’t a problem for you. There wouldn’t be all these threads if it were as seamless for everyone as it seems to be for you. Congratulations on that, but it happens to be a deal breaker for me.
- NightKITTEN321Oct 01, 2019ApprenticeHere’s my issue. My garage door connects to 2.4gz only. And it correctly connects to the Orbi router On 2.4gz. But when I pair my IPhone 8+ to the garage door it’s on 5gz. So the garage door app stops the pairing and says we aren’t on the same WiFi network. I tried turning down the 5gz strength to 25% but where I have to stand next to garage door panel to do the pairing the iPhone stayed on 5gz. I’d like to be able to get my Iphone on 2.4 GHz so that I can pair my garage door with my iphone so when I’m gone I can operate it. As it stands now I can still operate my garage door with the controllers but the smart part of my garage door is now dumb. I have talked to the manufacturer of the garage door and they say that mesh systems are very bad for security reasons (they are not easy to deal with and have poor engineers imo) and that it will never work and there is no work around. I’ve probably spent a grand total of five hours on the phone with Netgear tech-support adjusting different things in settings trying to get it to work and have had zero success.
Like I said the garage door is pairing correctly with Orbi but I need my phone to be on 2.4 GHz so that the garage door is seeing the iphone and the garage door as being on the same network. That’s my problem! Now I understand the advantages of a mesh network but you would think that Netgear would have some kind of feature built-in so that you could use legacy devices that were never designed for a new kind of mesh network. Many people have ran into this issue so you would think that Netgear would react to this and give us a solution. I have heard of some third-party solutions but I’m not very techy and I’m afraid that I would actually mess it up and be in real trouble.
If anybody has a solution for my problem I would very much appreciate it. Other than that my Orbi has worked perfect and I have zero complaints!
God Bless
〽️- ImuljiOct 01, 2019GuideI haven’t bothered trying further to separate the two although I’d love the ability ***to be able to ***.
You’ll likely get a response that NG built it that way etc etc etc. I was unlucky enough to buy from eBay where there were no refunds so buy carefully if this is a requirement.
