Franky_D
Dec 22, 2020Aspirant
RBK23 boot up time
Hello Community, I recently purchased Orbi RBK23 (router and two sattelites). First observation was, that it took a bit too long to boot up. It takes around 5 minutes. The first day when I wa...
Dec 22, 2020Guru - Experienced User
Ya, shouldnt take that long.
Franky_D
FURRYe38 wrote:Ya, shouldnt take that long.
It is the latest Firmware on all units (router and two sattelites) - V2.5.1.16. I bought all few days ago. While setting all up, the firmware got updated automatically. I have not had a chance to try it with old firmware.
It is cable modem/router is Sagemcom FAST 3890 V3. I am using Orbi in a router mode.
- FURRYe38Dec 22, 2020Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
What mode is your modem working in? If router mode, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
