TimD5000
Aug 23, 2019Aspirant
RBK23 connecting to NBN Arris not working
Hi I am trying to connect a new Orbi Netgear router to the NBN arris box. My service provider is internode and it looks like they only want to support a few router brands of their choice. Is it p...
michaelkenward
Aug 26, 2019Guru - Experienced User
TimD5000 wrote:
Model # is Arris CM
Not a lot of help. CM probably means cable modem. But Google shows a whole raft of CM model numbers.
The full details could be important. Especially of your "CM" is also a router.
CMs are only modems only. No built in router. C series modems are the modems with built in routers.
Thought it would be nice to know the CM#### model # here.
HE should be good a far as NAT and connection with the RBR and CM modem if there isn't anything else in between them.
- michaelkenwardAug 26, 2019Guru - Experienced User
That's Netgear. Google is less than clear on other brands.
Then there are variants with limited routering. Think DM200.
So I don't make assumptions.
- FURRYe38Aug 26, 2019Guru - Experienced User
I always presume that NG information is most accurate.
DMs are always DSL Modems. Modems only. D series is modem/router units.
